Tom Endy
Mr. 29FordGuy:
We did not record any dimensions. The man who did the milling used a set of forks that showed little wear to set up his mill. For lack of a spring tool you can compress the spring in a vise and tie it off with safety wire in several places. Then cut the wire once it is in place. Compressing the spring in a vice is somewhat tricky.
Tom Endy
Tom Endy
