Remember the seals in the original water pump are not designed for a pressurized system and your pump will leak. I am not sure how "leak-less" pumps would handle the situation. Also note you should have posted this in the section that deals with the Model A as you will have a better audience.
Charlie Stephens
I use 4lbs caps with no issues. Why not just buy a new cap with the pressure rating you want; caps are cheap.
Not being into newer stuff, I'm not real sure, but don't the different pressure rated caps have a special latching pattern so they don't get mismatched?
No, my modern Toyota cap will fit my Brassworks radiator just fine, and vice versa.
You can walk into an auto parts store and buy a cap off the shelf that will fit a Brassworks radiator.
I couldn’t find any caps with a 5-7 psi rating that will fit the Dakota rad.
I'd quit looking for a Dodge Dakota radiator cap, and figure out what cap size your radiator uses, and search based on the radiator cap/opening size needed.
The cap doesn't know what the make and model of the radiator is, and the radiator doesn't know what the make and model of the car it's sitting in is.
Radiator caps are pretty standard, there are different sizes and styles, but not many.
I did do that, but didn’t look for a long time. The issue is that almost all of those low pressure caps are from the 30s -50s from what I found from my digging. I’ll have to keep looking I guess. I might just drop by a local rad shop next week and see what they can come up with.
Hmmm. Looks like there still may be some incompatibility between caps and necks. The only example cited so far is a 4 lb cap and a Brassworks radiator. That doesn't surprise me, as the radiator is probably for an older car. There are other limiting factors (water pump seals for one) that may indeed cause the Brassworks unit to have been made for a 4 lb cap.
