Juggler,
try this bearing #CB-1623P
If I remember correctly the rear cap should be the later model as this bore will poke through the thinner recess sections.
John
John:
Does your solution with Saturn inserts require four (half) bearing shells for each journal? Is the part number you listed a GM number or an aftermarket bearing manufacturer? Thanks in advance for your response. Here's my pressurized A block; I brazed the main feed line and used epoxy (JB Weld) where the lines went through the bottom of the valve chamber.
I note also in the photos that the tappet cover mounting bolt hole has broken away from the block leaving the coolant passage broken into.
I imagine this might be difficult to repair?
Keith
Juggler,
John
John:
Which picture, I don't see it.
The one I've cut and pasted from an earlier posting below
Keith
