pressure plate
Al Bass
I had my flywheel and pressure plate resurfaced and the pressure plate fingers had to be adjusted a lot to get them to the right height (now I dont think the springs are putting enough pressure on the plate). Now that my engine is getting broke in, it is developing more power and is making the clutch slip when I excellerate. I think I need a new pressure plate. should I find a good used one, order a rebuild or order a new one. are the new ones of good quality?
I'll always buy new. I put a used plate in my coupe that was a "good one" per my late father. It was junk and a LOT of labor could have been saved had I just gotten off my wallet. Imagine how I felt when I relized I had to do it all over again.
Call james rogers at dream works he has a lightened pressure plate and a new clutch that works great . I put one my 31 s/w cranks so much easier . Easy to compress ,just works great.
Fingers should be adjusted to 3/4 inch below pressure plate outer surface, with clutch disc in place. There seems to be some debate about the distance, but 3/4 seems to have come from Ford literature.
I adjusted the fingers to 11/16 (had to do a lot of adjusting to get to that point) and the flange was surfaced were the pressure plate sits. What is the measurment from the flange to the flywheel surface ? so I can measure it when I pull the engine. Thanks
If you do go the route of the later pressure plate be sure you are getting the fly weight type. They have reduced spring pressure making the clutch easier to work.
Some shops are using the pressure plate for the tractor which does not have the fly weights. They have the heavy clutch spring and will work out your leg more.
