pressure plate bolt size?
37slantback
I searched around but came up dry. What is the bolt size for bolting a pressure plate to a 1950 flywheel? I believe it is the long style pressure plate with the 3 pairs of holes.
Thanks,
Don
Go to a speed shop; one of the big speed equipment companies like Mr Gasket or Moroso sells them packaged for '60's small block Ford.
book says 5/16-18 x25/64
Thanks Guys. I want to pick them up at a local bolt place but wanted to make sure of the size. I want to get things put together this weekend and have all bolts but those.
The original engine seems to have lost a seal last weekend. BIG puddle of oil under the old girl. I guess that was the last drive until I get the new chassis assembled.
The pressure plate clamping bolts are not something you can find at the average bolt store. The earlier suggestion about buying the special bolts supplied by your local Speed Shop was on target.
Fixed a car for a guy once, previous owner used standard bolts and probably didn't
torque them properly. Ended up with a new pressure plate and replacement flywheel.
Correct bolts are the only way to go in this instance.
I found some Grade 8 bolts of that size. Called the local "Speed Shop" and they said they had some bins of bolts to look through - LOL
I had made this suggestion in a previous post (without pic's)
The 3/8"-16 x 3/4" is what the Merc. manual calls for. (suspect same method could be used for Ford bolts) The result is virtually a duplicate of original.
You really MUST use the correct bolts, as mentioned above in few replies, using the incorrect pieces will result in a "vibration" in the flywheel/clutch area!
We see this while balancing the flywheel and cover ***'y, if the "shoulder's" aren't there and the cover isn't centered, it throws off the entire balance!
Thanks, Gary in N.Y.
P.S. Below is a shot of both sizes. We choose to not use any locking washers, it's one area we use "Loc-tite". Years ago we started drilling all the assemblies for 3/8" only bolts. Not a real big deal, and one specific customer specializing in the Flatheads wanted them done this way!!
Costly for the 6 correct bolts?? Any idea what it would cost if the Pressure plate came loose?? Thats a hand gernade if it ever sheared off cheap *** bolts.
So true, thats why they are costly
I don't recall saying to use "cheap *** bolts"
I'm wondering if Roy Nacewicz has them? I gathered up two sets (12 bolts) of nice originals that I had with my collection of flathead engines and sent them to a fordbarner in New England. I can't spare any more but maybe one of the several engine gurus who post here would have some extras they could send you.
