German guy Senior Member Jul 11, 2024 #1 Is it possible to adjust the pressure plate through the inspection cover?
German guy Senior Member Jul 13, 2024 #3 Suggestions as to how? Since the 5/8ths inch measuremement is from the bottom of the fingers to a flat work surface, could I use that measurement from the fingers to the clutch disk?
2 2speed Senior Member Jul 13, 2024 #4 https://www.fordbarn.com/forum/showthread.php?t=336127 I used the throwout bearing as a basis as it's the only thing you can reach easily through the inspection cover. It's a real pain.
