pressure brake light switch
cvicky
ive blown at least 3 in the last 4 yrs
again tonight brake lights don't work
swich is mounted on perportion valve on left inner fender
I've read that the Harley dealership will have a more modern switch that interchanges. Someone here will know the specifics.
TBird suppliers (like Casco or Hills) offer a kit that replaces the pressure switch with a mechanical one. It operates off the brake pedal arm.
Don't buy anymore of those cheap chinese made brakelight switches. They are guaranteed to fail in short order. Both the seal inside and contacts are substandard. The cheat on everything.
I got a brakelight switch for my '55 from a motorcycle performance shop. It is set up to accept Dot 5 fluid, but I suppose you could still use Dot 3. It's been in there for years now and I get a lot of use out of it. You will need to do wiring terminal modifications to use the motorcycle switch, but it is the right pipe thread size and looks the same as the Dot 3 switch, except for the wiring.
On my 54, I made a bracket that mounted on the firewall brace that the brake and clutch pedal are mounted to and installed a mechanical switch off ebay. Has worked great for the last 8 or 9 years. I have a write up on it if interested.
they have a brake switch here in Ottawa at Harley dealership 72023-51E $27.
i'll try it thx
if that don't work i'm going mechanical
Painless Wiring makes one I've seen people use, it trips at low pressure. The one that came with my distribution block leaked immediately. The one from NAPA started out okay, but quickly took a lot of pressure for it to work. I now buy one on eBay that works fine, probably have 9000 miles on it. I carry a spare as well.
