If I had about 50 servants, maybe I'd put one to work preheating my rides...
You're RIGHT, Ian,
I made a DUMB statement!----Here, I'm just sleeping under a sheet & my flowers are BLOOMING!
Bill W.
Like to welcome all the Siberian Russians to the forum. (drain everything preheat... I'm still laughing) I drive in winter, "A"s hate the cold and will run like crap for 5 minutes, after 5 minutes start driving, enjoy calculating the viscosity of 600 weight gear oil at minus 20 degrees. Expect ****** to start behaving like a transmission after 15 minutes. I will state that if you are ever in Antarctica in the winter with your Model A, draining the radiator and preheating oil would be necessary. After it warms it she will run fine any temperature.
The charcoal and kerosene fires under the oil pan are a hassle. Getting up early to start the fires and wait for the oil to warm is a pain.
In the mountains west of Denver 55 years ago I just placed an empty gallon anti freeze can with light bulb socket mounted inside under the oil pan. Set the can on top of a brick up tight against the oil pan.
Put an other under the ******. Cut the can in a shape so that less of the heat could escape.
I used a 150 watt bulb unless it was really cold, then a 200 Watt bulb usually did the trick.
I know that does not work if there is no electricity! In that case I had a Primus gasoline one burner, back pack stove that I put inside the antifreeze can.
In Michigan we walked a mile to K thru 5th grade school and a mile back home ... it was really hard because it was uphill BOTH ways.![]()
"BOTH" ways--Now that's funny! When the roads were MUDDY, we rode an OLD Horse, named SHORTY, he was trained to kneel down, so little Kids could get on him. Rode bareback, until Uncle Mutt loaned us an OLD saddle & Grannie sewed up a set of saddle bags for BOOKS, & CORN for Shortys' LUNCH.The charcoal and kerosene fires under the oil pan are a hassle. Getting up early to start the fires and wait for the oil to warm is a pain.
This is one time I disagree with the Guru of Stuff. If you are starting in very cold weather, it is helpful to have some sort of pre-heat. Back in the day, I used to have a Davey Lamp (safety kerosene lamp) under my vehicles in cold weather. Now I use block heaters. If you are planning in starting the Model A in temperatures colder than freezing you might consider some external heat source. My father-in-law used to throw an old blanket over the motor and tuck a 100 watt trouble light under it.
