AZ Chris
On a couple of occasions when testing things the ignition has been left in the ON position for an extended period of time causing the coil to boil.
Running a Mallory 58K V coil with internal resistor along with a Mallory dual point distributor.
Thinking we could add an external resistor but that would only drop the voltage and slow the problem. Adding a toggle from the ignition is the easy fix but could still be forgotten.
Haven't found anything in a search, has anyone come across this and how did you resolve it?
Thanks
Thanks
