Better asked over on the HAMB forum of the Jalopy Journal.I have a 1941 Ford coupe with a 350 engine and would like to put power steering and brakes has anyone done it before and if so what did you use. Thanks Jerry
if your M.C. is under the floor) will require a new pedal assembly.
Chassis Engineering has an adapter that will mate the original pedals to a Pinto double diaphragm booster. I used a No-limit engineering Corvette M/C adapted to remote fill. I found a VW dual chamber reservoir that can be mounted anywhere above the M/C. This M/C was for front disc, rear drum. The pedals mount in the same location just spaced out maybe 1/2". If you need a PIC send me a message. Sorry I can't post PICs here, never figured out how to do it.
This is the setup i'm using, check it out at ECI.Thanks for the link. They have an MC I might use. They don't have the MC to remote fill adaptor any more. They have MC with extra ports to pipe from either side that I didn't know existed.
http://www.nolimitengineering.com/products#!/Brake-Parts/c/8625919/offset=0&sort=normal
