Mitch//pa
dad and i were talking about using a power probe. i have a couple of them and regularly use it on my model A for checking power, grounds and continuity. the better one i have has an led screen which shows actual voltage. connecting the negative lead to the starter cable and the positive to a head nut the read out should show battery voltage with the engine and key off. my car showed 6.4 volts which tells me my battery cable to frame connection is good and my battery connections also. i can touch the power probe anywhere on the frame, headlight buckets etc and it should show the 6.4v. now if it shows less than that i would know i have a bad connection at that component. this tool is very handy and easy to use for any hobbyist versus a test light or most functions of a multimeter. with a test light you can only go by bulb intensity vs the power probe actually shows voltage. with my car running at high idle no accy's on and running a Tom W. evr my charging voltage is 6.7 on the screen. testing voltage at the coil shows actual batt voltage and is easy to do. checking to see if the points are operating i touch the probe to the red wire at the coil and with car running it alternates between power and ground. whats easy about using this tool other than an exact voltage readout is it automatically switches when checking plus or minus but when using a regular test light you have to switch the leads manually. i can go on and on with other easy tests also but i think i bored you guys enough. all in all its like an easy to use do it all modern tool...
