I was hoping I wouldn't have to cut the floorboard, but if I can't find another switch I might have to do that. Thank you. DonIf I picture it right, cut an access hole in the plywood floor board to access the switch, that's what I did.
I cut a round hole in the floor board, mounted the switch on the cross member supporting the front seat. The switch handle sits just below the floor surface allowing me to make a round sheet metal cover that swings over the hole. This way I can open and close it when I switch the unit on or off. This is on a 1930 Tudor.I was hoping I wouldn't have to cut the floorboard, but if I can't find another switch I might have to do that. Thank you. Don
