power brakes
carguy01
Good morning, does anyone know of a company that makes a direct bolt on power brake booster with cylinder for my 55 ford fairlane.I have installed a fat man front end complete with disc brakes and rack and pinion Ralph
I used the power booster, master cylinder, bracket and proportioning valve from a Ford Granada. The bracket bolts up to the existing 4 bolts on the firewall (two of which are for your original M/C. I'm using Granada Discs and spindles also. Rear brakes are, you guessed it, from a Granada, as is the 8". Makes it easy all the parts were designed for the same car.
Or you can try Stop N' Drop for their M/C power booster
