40cpe
The current thread on power brake boost brings my issue to mind. I've started another thread so as not to confuse the two symptoms.
The booster on my '55 with a stock 272 works wonderfully most of the time. Occasionally when coming to a slow stop I will release the brake partially and then reapply. Sometimes on re-application the boost is gone. I'm moving slowly at these times and am able to increase the pressure on the pedal to stop. Single and double diaphragm, 7 and 8 inch boosters are mentioned. Can the booster be identified by these pictures? The best I can tell it is 7" at the larger section before the step-down. This seems more prevalent when the AC is on and the engine idle is lower. I've been thinking of a reserve canister and a convenient space is nearby in the fender well. Any other options for me?
