John the carb cooling is easy to solve, Just a 1/2" vented phenolic spacer cures that. The heat from the intake manifold heats the fuel pump. A steel intake has a little more clearance then an aluminum one. The aluminum manifolds just about touch the fuel pump. I even tried raising the pump 1", making an insulator between the pump and manifold and even a high speed computer fan above the pump plus insulated fuel line from frame to pump. I tried each of the items by themselves and each improved but did not eliminate the vapor problem. All of the above items pretty much cured it by looks like Rube Goldberg under the hood. Don't forget I have the advantage or disadvantage to having 90 degree weather for months at a time. When testing I go the same route of about 25 miles each way and stop for lunch for 1/2 hour. I carry the laser thermometer and jump out and take readings. Also take them at start of the run, stop and after sitting 1/2 hour. This also gives me the start characteristics. I usually open the hood in real hot weather when I stop this really gets rid of a lot of heat. Some year Fords have less air movement at the rear of the engine where heat builds up and stays longer. The valves in the gauge line are to be able to Watch the pump or needle valve function. The 39 deluxe is about as bad as they get. John give me a call and ride up to Honey Brook some day, I'll buy lunch. G.M.
The fitting with the shut off valve to the right of the gauge was to try a slight fuel bypass line back to the tank. This should solve the vapor problem in the pump but haven't tried it yet.
