Are gas caps the same size as radiator caps? Is it posible to put a gas cap on a radiator?
I was driving on a pretty warm day, up & down a few hills, when antifreeze came out from cap because temp was over 200*F. Stopped to let the car cool down & all was fine after.
Gasket is good, but I was wondering if I had a vented gas cap on my radiator.
Guys I had the same problem ! i took the radiator to a radiator shop & bad it boiled out & repaired, but it did no god. they were afraid to try to rod it out for fear of destroying it. I put it back on the car & had the same problem all over again! would loose coolant on a long hill or a hot day. turned out that the radiator was about half plugged & the water pump was just simply moving more water than the radiator could handle. I broke down & bought a new aluminum radiator & problem solved.
I'm afraid this is a common myth. It is not possible for the pump to move more water than the radiator can handle because the ONLY place the pump can get water is from the bottom of the radiator (via the engine) I suspect that when your radiator was tossing coolant out, the coolant was boiling, thus increasing its volume.
Whatever, it is fixed now so enjoy.
Not agreeing, not disagreeing, just need more explanation.
1.5 gals in the radiator, 1.5 gals in the motor/hoses. If the water pump pumps more water than can flow through the radiator, why can the pump not continue to pump/draw the 1.5 gals from the block causing pressure, pumping water out the overflow and/or an ill sealed radiator cap?
Closed Cab, Let me try to answer that question by asking another: What is going to replace the water taken from the block?
Exactly. When the radiator is partially plugged, the lowest pressure of the whole system is in the engine block. Lower pressure = lower boiling point = coolant flashing to steam = expansion of flashed coolant by 1700 times the volume = coolant pushing out anywhere it can. Fix the radiator, fix the problem. Reduce the water pump volume = bandaid fix that may get you by but not indefinitely.
Yep, and the lowest pressure of all is going to be in the head... right where you need it most. Does anybody know why Henry thought a pull through cooling system was better?
DHZIEMAN: Where should the gav be set? Rich? Lean?
Rereading this string, looks like this was not answered. Plus am summarizing what may be happening.
A good starting point is to read the recommendations in the Model A Owners Manual. There should be a free download available on line if you do not have one. If you can not find it, ask here, someone probably has the link.
Depending on the car, adjustment of GAV and Spark Lever varies. Depends on the condition/wear of the car, and how the base settings are adjusted/calibrated.
At speed, with engine warm, under load (hills) GAV should not be set too lean, can make engine run hot. Usually should not be set less than 1/8 to 1/4 quarter turn open. If the spark is set retarded (lever up), and the GAV is not set correctly, motor can backfire, especially at low speeds.
Spark lever under same conditions should not be either over advanced lever down) or overly retarded (lever up). The tendency is to run with the lever fully advanced (lever down) on hills since it gives you the most power, but this is not good on the motor.
A rule of thumb is to set the Spark level to match your speed when adjusting the lever, half speed/half advance, full speed/full advance, idle-very slow speed/not full retard but a few notches down on the lever. Lever full up retarded, only when starting and once motor pops/runs set down a few notches. At idle it is ok for a very short time to run full retard, not really great for the motor, and causes motor to heat up, amongst other things.
For your issue your having, try the same route repeatedly, and try different settings each time. Write down the results.
What would be very helpful is if you had a coolant temp gauge, the type where the sensor is in the head upper coolant neck, with a gauge inside your A. Makes it easier to diagnose, and handy to keep track of Temp if a problem is about to occur. Moto meters give you a rough view , I find a temp gauge a lot more useful.
I suspect your issues are not GAV/Spark setting related. However these are easy things try and rule out in the progression of trouble shooting cooling issues. IMO these may help, but are not the real cause of the problems. Cooling issues are; marginal/bad radiator, bad head gasket, excessive buildup of rust/scale in the cooling passages in the head/block.
My opinions based on my dealing with cooling issues, opinions may vary.
