1932 V8
Hello , I seem to have an issue with my 32 when she has been driven for a while. The engine runs nice and cool , 170 deg , and she runs great when cold and in the first 1/2hr or so . The more it is driven, like a 2 hr ride down the freeway, it will start to run rough and have a stumble off idle. It will not take a hard load meaning going up a hill , the more you push it the worse it is . I have perfect fuel pressure at all times , 2.5 or so , and I believe it is ignition related .It always starts and it is reliable . We just got back from Deuce Days in Canada and drove the car about 2000 miles. It had the issue the whole time and it was consistant. At 65mph when warm you can hear it running a little rougher than when it is colder like when we first got on the freeway. Basically , the more heat the worse it ran but if you pulled over for a gas stop and let it sit for 10 min it would run better . I am going to move the coil and see what happens but I was just looking for opinions on the coil getting hot from the header tube . To close ???
Thanks , Mike
Thanks , Mike
