Ken Henry
Hi everyone, I had a major wreck in my 51 Ford on July 30 and it's unfortunately totaled. Thankfully there were no life threatening injuries, though I did break my pelvis. At this point I have let the car go to the insurance agency and declined an option to buy it back at $3500. This means it will go to auction through a business called copart.com (Rochester, NY location). I am not familiar with copart.com but would like to think the vehicle will sell for considerably less than $3500. The auction is not scheduled yet but here's the link:
https://www.copart.com/lot/63476033/1951-ford-other-ny-rochester
I do not plan to bid on the car and am simply offering some info to the group as a public service announcement in hopes that of some valuable parts go to good use. Keep in mind I was unable to verify that any of these components survived the crash.
The engine has 1,968 miles on it since an expensive rebuild (ugh). 8BA block was prepped by Al Clarke in Albany, NY, 4" Mercury crankshaft, Ross 3 5/16" pistons (276ci), metric moly rings, Zephyr valve springs, Schneider 248F reground cam with 0.350" lift, "full"-flow oil filter conversion, EAB heads milled and painstakingly clearance to piston tops and for uniform 69-70cc chambers, 10" clutch and diaphragm pressure plate, Edelbrock dual carb intake. I was running custom fuel injection throttle bodies and a distributorless ignition system, but it could be easily changed back to carbs and distributor. The engine made amazing power compared to stock and really woke up my old Ford for its last few thousand miles... No cooling problems at all. One final note, the rear cam bearing was installed turned 90 degrees so electric fuel pump is needed at this point.
Other details: 49/50 OD transmission. Most body panels are damaged except pass door, pass, fender, trunk lid. Both bumpers looked excellent still. Some of the grill chrome is OK, probably the seats (~10 year old EZ boy upholstery).
If someone here buys it I would be interested in acquiring back some of the fuel injection components.
Let me know if you have any other questions about the car or engine build. Also please add any experience with copart if some of you have it. The accident was due to my stupid mistake and I don't feel like commenting much further other than that the Ford held up well against a 4400# Toyota Highlander. I installed 3-point belts 10 years ago and am glad I did... Ken
IMG_4457 by kenhenry_06268, on Flickr
0A123251-307B-42A6-BCB7-1AFA70AF1D46 by kenhenry_06268, on Flickr
