Rustynutz52
Installing a Posies front spring in my 37 ford. I have the assembled axle w / spring raised up into the front crossmember, but I think I might be missing something. It appears that I only have 2 flat bars to bolt to the 2 front crossmember ubolts. These will not tighten down on the spring as it appears the posies Spring assembly is not as thick as the Original. Old cotter pin holes not even close to the nut.
Thanks
Mike
Thanks
Mike
