flatmotor40
Just started.Went to store and came out and seems to run a little rough but then when I stepped on it from red light a pop from the exhaust,Did it a couple times as i went heavy on throttle.but it seem to run a little rough.It has done this before but it was moisture in cap.Frt cap 59ab.Checked cap when I got home no moisture.Cleaned it and put it back on.Cranked up and at high idle ok but rev up a little more and a pop.Removed plugs and looked good.Compression check 135 -150.But my gauge leaked down as i held it.Old gauge.Need a little help.Have 2 97's for Clive and 1 of his electronic dist.Thanks
