popping issue solved
oldskool
JDL nailed it it was the vacuum advance . i replaced the carb with the correct 8BA unit,and replaced the bad vacumm advance unit ,i also regapped the plugs to .025 ,the engine purrrs like a kitten,took it for a spin and runs like a top never ran this well,thanks all this site have been a great help and i learn something new every day..al :D
Glad to see a response when a problem is solved. We out here viewing the forum alot of times never know what solved the problem(s).
oldscool the problem is when you replace 2 parts of which either could be the problem you really don't know which one corrected it. Always change one part and run it before changing another part then you know what caused it. G.M.
well i had the wrong carb 46-48 ford carb no vacumm port and the vacumm advance unit was shot,so changing both was the only way
