29tudorsedan
I am going to install a Popout in the car, right now the ignition cable is an armored one, but doesn't have a clip secured to the stud.
The stud the clip should go on is flush right now with the bolt, my question is wil there be any problem if the clip is added and the bolt can't lay flush over the stud?
Two of my studs on the head lay higher than flush, one on the corner near the passenger side, and then another three bolts forward from that. I can post a picture if needed.
Thank you
Thank you
