Hi, I'm having a problem with spark on my '31 roadster. I have replaced plugs, condenser, points. The distributor lower plate is fairly new. I have power to the point arm but it won't jump to the point block. Is there a short that I missed or would the coil have this effect. Normally I can troubleshoot most things but I'm stumped.
end quote
I'm not sure what you mean. Power should not and won't jump between the points contacts when open. As Tom said, if you 'jump' across the contacts with the coil secondary wire about 1/4" from a good ground you should then see a spark. If not, jumper wire the fixed point contact/connector/ground to another good ground and try the above again. If you then get fire then you have a ground issue in the distributor or distributor to block. If still no spark, clean the points contacts. Clear as mud, huh.
