Jerry in Shasta
Restricted exhaust or dragging brakes??
I think if you can get non ethanol gas that will be your best improvement in mileage. GaryBruce,
You mentioned ethanol spiked gasoline early on. I do not know what part of Virginia you call home but there are close to 300 gas stations in this state that sell non-ethanol gas. Click on this link and see if any are near you. I have seen a 10% improvement in fuel economy in my own vehicles by using non-ethanol.
http://pure-gas.org/index.jsp?stateprov=VA
I hope this is of some help.
Bruce,Need some advice on improving the gas mileage on my A Model (1929 Tudor w/ a Zenith B carb on a 31 engine) First, my odometer has been checked; it works fine. I have no fuel leaks. The car starts & runs fine. I start it cold w/ full choke, GAV 1 turn out, spark fully retarded. As soon as it starts, GAV to ¼ turn out, spark to ¾’s down. I rarely move the spark advance from ¾’s as I rarely exceed 45 mph. Timing is dead on. The timing pin fits easily in the slot in the gear; trailing edge of the rotor is just opposite the #1 *** in the distributor as points just start to open as observed w/ a meter. (I gained about 2 mpg after adjusting this) Timing confirmed w/ a light & marks on the crank pulley. Points set at .018 & confirmed w/ a dwell meter at 31*. Advance works as it should by observing the timing light. Plugs are a light brown. Not that it needed it, but carb was soaked in cleaner, blown out & rebuilt w/ all new flow tested jets, nylon jet gaskets, etc. Carb idle was checked w/ a vacuum gauge. Float level checked w/ a plastic tube; 5/8” from the carb seam. What can I do to improve the current 12 m.p.g. gas mileage? Thank you.
This discussion always gets me down. I feel like Bruce, that I've done just about everything to properly tune and to reduce drag, but get 9 or 10 mpg, and have for 25 years.
That's due to California smog. You need to burn clean air.
My 28 stock Phaeton gets 22 MPG on the open road, but only about 17 in town.
