tucker6077
Would putting in a colder or hotter plug help fire a lower compression cyc? 1933 ford 40, aluminum heads. Also any known reputable mechanics to work on this vehicle in NJ,PA,OH,or Delaware
a cyl. leakdown test might shed some light on the low compression.
If you happen to be using Champion plugs, I've seen many cases where once they're fouled, they will not fire again.
Well That last post has given me hope ! Anyone know of a flathead mechanic in NJ ?![]()
