Keith True
Larry,I can actually advance it a little more when running flat out,but not too much.I found that if I retard it any more it runs a little hotter at an idle.I have moved things around and found the best spot for this particular truck.It is .060 over,with a B cam,a B profile dist.cam,stock ignition,and I don't know if I have the 5.5 or the 5.9 head from you.I bought a couple of blems,and I can't tell the blem from the drivers seat.With the stock head I would start the truck at full retard,then pull it down a couple clicks.Taking off and around town,or under 45 I run the lever halfway down.Then,when flat out I pull it all the way down.It felt right and worked right.All my cars are very sensitive to the spark advance and GAV controls.With your head I only touch the GAV to make sure it has not vibrated out any or to use the choke.The car takes to the throttle instantly,when cold,and I can drive it out of the garage to warm up instead of sitting in it for two minutes inside waiting for it to be able to move without spitting and stalling.I also realize I have it a little advanced in the static timing,but very little,and the car seems to behave the best there.NO kickback on starting,even when very hot,and when warm it starts on one lift of a piston.If I come to a stop with my other cars I have to retard the spark,if not they kick and roll a little at idle.I really think most people don't notice it.In the car with your head on it,once it starts I can pull it down a little,maybe between 10 and 11,and leave it there until I am wide open.Then I only pull it down a little more.The exhaust smells cleaner,the car runs smoother,more power,it is hard to lug it because it just takes off when you step on the pedal,I just like it.And,one other thing I forgot,my pistons protrude a little more than they should.The block has been decked too many times.I don't remember how much,it has been probably 25 years since I measured it.It can't be too much though,I check clearance when changing heads and it has never been an issue.
