Earle
Terry,
I had (have) the same moderate concern about bearing loads. My roadster had newly-babbitted rods installed during a rebuild about 25 years and 6500 miles ago. About 2000 miles ago, I had a Snyder 5.5 head put on. The increase in power and performance was noticeable. 'Loved it! Then, a couple of months ago I began to hear a tapping/knocking sound. All four rod babbits had failed and chunks were found in the oil pan.
Even after examination by a very experienced, excellent Model A mechanic/re-builder, it is not certain what caused the failure. He suspects a bad pour and workmanship on the babbit job, but also points out the increased loads that are imposed on the bearings by high-compression heads. The higher the compression, of course, the higher the loading. If my rod babbits were bad to begin with, my H/C head only served to accelerate the failure that was going to happen anyway after who knows how many more miles.
I have to believe, though, that H/C heads will reduce bearing life but maybe not enough that the average 'A' owner will ever drive enough miles to notice. I have to balance this with stories of the many H/C heads out there that the owners claim many happy thousands of miles with!
I took a gamble (also due to homework and success stories) and had the babbitted rods replaced by the new forged insert rods from Antique Engine Rebuilding. The mechanic also strongly recommended driving a lot less with the spark fully advanced to reduce bearing loading. AND - NO LUGGING!
The inserts are runnung great and the engine is happy again. I'll still stick with the H/C head and just be way more careful when driving. - But, I wouldn't go above a 5.5:1 head! That's just paranoid ole me... These failures are VERY expensive!!
Earle
Earle
