Poll Regarding Accessory Gauges You Prefer
Bob Bidonde
This post is a poll to determine your preferences for the type of accessory gauges you have or would install in/on your Model "A". Choose from the choices listed:
Clock
Coolant Temperature Gauge
Electronic Tachometer
Manifold Vacuum Gauge
Motometer
Oil Pressure Gauge
Motometer
Thermoquail
Voltmeter Gauge
Coolant temp gauge for sure. Now that I have one I would not go back to having an A without one
Temp and oil pressure. I also have a voltmeter that was helpful in a diagnosis.
I have a Burtz, on a stock Model A, oil pressure I'm not sure I would need, but temperature is a must.
Just one - water temp. Our Coupe came with a Brassworks pressure radiator a thermostat housing and old style Stewart Warner wing gauge.
Our Tudor has no gauges but as long as the muddy looking water isn't puking out of the radiator I figure it's OK.
In order of checking frequency:
  1. Speedometer. (GPS, my speedo not accurate)
  2. Voltmeter
  3. Ammeter
  4. Gas gauge
  5. Temperature (at coolant outlet aka goose neck)
  6. My wrist watch
  7. Oil pressure
  8. Tachometer
Haha, I do have Ms. Garmin suction cupped to my windshield At least it has a Model A for the cursor). Doubles as my Speedo and Odo since my "Rebuilt" Speedometer does not read correctly. And it helps me find my way home...
I also have a Water Temp and a Moto-Minder. Plus a clock in the rear mirror.
My shifter knob clock and Rex-A-Co temp gauge!
I have oil pressure and temp gauge in my A's. I figure that's all I need to keep an eye on things.
I can't decide so they stay in the display case:
574331
574332
.....etc.....
Brad in Maryland
Clock? No. I wear a watch.
Coolant Temperature Gauge? YES!
Electronic Tachometer No. My hearing is still good.
Manifold Vacuum Gauge. About as necessary as an altimeter
Motometer No
Oil Pressure Gauge No
Motometer
Thermoquail a nice decoration but not a gauge
Voltmeter Gauge I do not need to know while driving
coolant temperature gauge when I was driving long tours in the summer.
none needed for my beater truck just driving locally......
Side note : modern cars are getting away from touch screens and going back to knobs and buttons ! About time IMO
In my carry tool box I have IR temperature gun, VOM, a test light, a screw driver for removing the oil plug on the side of the engine to check for oil flow, a calibrated wooden stick for double checking the gas level.
