The starter motor will work with either polarity. The coil must be wired correctly, negative to negative and positive to positive. Some coils will say BAT and DIST or something like that. These coils are for modern cars which have a negative ground. So the BAT side should be hooked to the positive side of the battery an the DIST side run to the distributor. If in doubt whether you have it hooked up correctly, check with a volt meter.
