As Brent said the points aren't finding ground and my first guess would be you need to sand the points.
A quick and easy way to find the fault is to take a wire and clip one end to a good ground, then touch the other end to the distributor body and see if the 6 volts drops to zero. If it does, then the distributor needs a good ground. If you still have 6 volts at the points, then touch the grounded wire to the points contact and see if you loose the 6 volts. If so, then you know you need to clean the points.
