The modern point plates I have seen fit very loose in the center, a lot of possible dwell change, in looking at original Ford ones the hole was ground to size for a good fit, the reproduction and modern plates are just a rough stamped hole--- that in itself to me makes them a downgrade from original parts,
I like the original points, still using thee set that came with the car, though after 40 years the rubbing block is worn some , someday I will use the new original Ford ones I bought for 1$ at Hershey
I would consider the A&L condenser as more reliable than what is sold with "modern" points,
