keyswitch1
What should it be set at ?? Thank you !!
That is a really neat way to figure it, never heard that before.I don't always have feeler gauges handy, but this is a little trick I figured out and find very handy.
The standard threads for the adjusting screw on the ignition points is 32 threads per inch. I put the points on the high part of the cam, turn the adjusting screw in until the points just close (a powered test light helps), then I turn it out 5/8 of a turn, which is easy enough to eyeball. That will put you right at 19 thousandths.
Ken
Ken, I am confused and not a great Model A guy but it would seem like you should set the can when the points just touch the LOW part of the cam rather than the HIGH point. Am I all messed up in my thinking?
Pretty much.40 Deluxe the guys you are referring to are the tinkers. They can never leave things be. They are the ones who will never install electronic ignition in their cars because they would go nuts not having something to tinker with.
