Plug Connectors?
IrishHills
Anyone proud and have a picture of how you bent your plug connectors to fit the taller Champion plugs? I don't have much of an imagination and thought I would ask before bending them around.. thanks Ray
If you are referring to the brass straps then just bend them. The angle changes a bit but they just bend on mine and go right to the D. body.
Mike
There are two kinds----regular and offset, just make sure you have the right ones.
Kind of hard to do it wrong----they're pretty forgiving..
Jack
There are also two qualities of plug straps. The incorrect soft brass straps, or the springy correct bronze straps. Ask for the bronze ONLY.
