I would like to get opinions from some of you guys on here about the value of my model a. I am 22 years old with a lot of buying and selling experience in this type of stuff but may not have as much as a lot of you. I am pricing my pickup because I am thinking of selling it. Here is the best description on the truck I can give and I hope to soon have some pictures added.
Late 1931 Ford half ton truck cab setting on a 1931 coupe chassis
The bed is from a 31 pickup and has tailgate . All four fenders from the coupe sill mounted. Right now the truck is complete and is a driver. I drive quite a bit and spent and five days in it stuck in Austin,tx last week. All lights work. And brakes work.
The cab is in patina no paint as well as the rest of the truck. The chassis has no issues, no areas in need of mechanical attention. The hood is in great shape with original paint on it. The floor has been installed and has new carpet, new comfortable seat.metal roof bows put in top with a fabric top put in.
Brand new modern style points and condenser on new distributor ,new water pump, new battery,new wiring,new exhaust manifold andintake manifold.new electric fuel pump and regulator and lines.
The truck runs well and drives well. It is ready to go but the rear fenders are beat tp and rusty and the fronts are fair.the running boards are shot. Has good tires. The original horn works, the original stainless headlights work with no broken lenses, no dents or rust all in th buckets ,the motor also has about ten thousand miles on if since last rebuild. Motor runs great and ****** works well I drive the truck slot
I am just wondering now what you estimate the value of itwith the info I have given.? Thanks
