Licensed to kill
I know when a bearing goes in a motor with shells it knocks and, especially with the throws will soon turn and score the crank and rod journal but what happens with poured babbit??. The babbit on shells is supper thin and things so sideways quickly once yet gets down to the copper but with poured babbit being relatively thick AND the fact that these are intended to be adjusted for clearance occasionally, what happened exactly???. What sounds do we listen for to indicate that the clearances require adjusting and at what point is it too far gone.In other words, since they are not shell that will turn, what happens, does the babbit start to fall apart or what?. How often should the clearances be checked?.
