pitted transmission gear teeth with
Herb Concord Ca
I took apart a transmission that was given to me last year.
I noted that the cluster gear, the first/reverse gear and the second/high gear had teeth that had pitts on them.
I've heard for years not to use gears with pitted teeth, but what problems do they cause?
Thanks
Most of the trouble it will cause is noise and maybe a bit faster wear of the surface. If you are building a parade car then don't even worry about it.
