Leatherback 57 Member Jan 4, 2018 #1 I want to freshen up my 15 engine. Has anyone used the higher compression pistons and will it add some torque without over stressing rest of engine
29spcoupe Well-known member Jan 4, 2018 #2 High dome pistons should be OK for an engine with good Babbitt. Do not combine high dome pistons and high compression head.
stevests Well-known member Jan 4, 2018 #3 I've done several "pop up" piston jobs - just as much or more "poop" than a "hi-compression" head and less expensive !
