I was able to free up a stuck piston on '30 truck. Short of pulling out the piston , how do you determine if rings are still frozen. It turns over well now and I have sprayed a good deal of blaster in there . John
Check for a ridge at top of cylinder before beating the piston out, and cut the ridge away if it exists or you will definitely have stuck rings. Good luck
