From Mikek's description it appears that I will pull the pistons and 180 deg them so the tongue is on the cam side. No answer from Macs or Snyders ,I e-mailed them both.Thanks
Tom I can't tell now because they will be staying in place. I believe they may have been the Silvolite pistons as mentioned by Ursus. Should have her running this weekend.I will let you all know how it goes.
I found a old piston stamped front from the factory and the slot is on the drivers side. On all the pistons I have seen the slot is in the tongue, so judging from this piston it seems the tongue goes on the drivers side. I do not know if it makes a big difference or not.
