piston rings question
Brubaker
Unmarked with regards to the bore. Is the part number(M1025) significant? Could it translate to .125? Thank you in-advance for the help.
Brubaker - I am just guessing here, but my interpretation is .025" over.
However, take a ring and close it to the gap it should be, and then measure the diameter. That figure should tell you what the cylinder bore diameter would be.
Others may have a better way of doing that.
Thanks Ron. I guess I thought the bores were in even increments. Much to learn(taking it one part-at-a-time).
See if you can put one of the compression rings in your bore and measure the end gap with a feeler gauge. If they're right for your bore, you should have about 0.004" x bore, or about 0.015" end gap.
This is NOT a 'what is it worth', but more of a 'is there value?' question. When I get to my engine, I have someone lined up for the rebuild job. So, I have a set of rings that need to find a better home. When the engines are professionally rebuilt, are there specific piston rings that most folks buy(new)? More directly, do older rings have value(manufacturer unknown)?
.025" oversize would be an odd number. Pistons generally come in +.020, .030, .040, .060, .080 and .125". Granted you will occasionally see other sizes but not commonly. I would think M 1025 is a part number???
