Glenn C.
One of our club members, purchased a really nice 29 Tudor with a "B" engine, other than it came with a Model A head and water pump. After driving the car a couple of times, he noticed it overheating consistently after short runs.
After the usual engine checks and inspections, such as compression check, leak-down check, stethoscope check, it was decided to overhaul the engine completely.
After tear-down and hot tanking at the machine shop, cracks were found in the block between #2&3 & #3&4 power cylinders, which were repaired by the "metal lock" system.
After engine assembly, the engine water jacket had to be crack sealed to prevent water leakage into the cylinders. Model B head gasket was used.
Problems are: The vehicle continues to overheat (120F+) after only a few miles.
Without allowing the engine to idle more than a couple of seconds after shutting down to remove the spark plugs for inspection, all cylinders show signs of oil in the combustion chamber and on all the spark plugs.
Leak-down test of all cylinders, show that the rings have not been sealing.
This Model A owner probably was too passive in breaking-in his new rebuilt engine.
Question therefore is: Has anyone out there in "FordBarn" had any experience with good luck, using a powdered cleaning product, such as "BonAmi" slowly ingested (sprinkled) into the carburetor intake to facilitate re-seating of the glazed-up cylinders ?
Your help and comments would be much appreciated !
