Tom Endy
When installing new rings in a Model A engine how important is it to check the end gap clearance on a set of rings. What should the end gap clearance measure on a standard bore.
When you order a set of rings for a given bore size can you expect the end gap clearance to already be set?
It seems to me years ago a mechanic would place each ring down into the bore, measure the gap and grind the ends to achieve the desired gap.
Tom Endy
Tom Endy
