Piston question
Craig CT
With the 8BA pistons on the full floating rods what small end bushings are used, do 8BA and 59A use the same small end bushings? Thanks, Craig
All flathead pins are the same size .750 SO, use the bushings for the rods you are useing. There are 2 differant size bushings, a few .000 od. Walt
