lesterwa58
I have a 1980 Pinto made in Sept of 1979 and I need a replacement column turn signal switch. I have purchased turn signal switch, Ford # REPF505802, but this does not fit my vehicle. Is there another switch that might work?
Where might I search for the correct switch. I am assuming this is a module with the turn signal lever on the left side and the four way flasher mounted on the lower right side of the column, the switch has connecting wiring that goes down the column to connection to the four way and turn signal wiring. If you know of a source for me to contact please advise. Wes Jones, Cle Elum, WA
