I am now set to reassemble my 39 differential. I have done a lot info gathering and have found differing requirements for the pinion shaft bearing torque requirement. The 39/40 Engine and Chassis Repair manual says use 15lbs (but this setting might be unique to the tool that is being used). Vern Tardel's Banjo-Differential book says to use 15 foot pounds. Many of the post here and on that HAMB say 15 inch pounds.
My guess is that 15 inch pounds sounds correct, anyone care to comment? By the way, is this measurement taken with a unlubricated bearing, with diff oil, or grease?
