This is not a banjo rear end, its a floating axle in a 38 one tonner. The pumpkin was full of water when I opened it and now I am trying to disassemble as far as I can. The outer pinion bearing was not as bad as expected but still had some pitting and will replace. The two inside pinion bearings are now spinning freely and will leave them if I cannot find a safe way to get them out. Also, I assume the pinion bearings are lubed from the gear lube in the differential not packed with grease, please correct if wrong. Just looking for advice......
