As far as I know Mitchell only makes one base unit for the A's. The shafts and tubes are adjusted in length for what car it installed in. You could use the connecting sleeve to get extra length.
Bolts would not work. You would need ether bolts with full thread with nuts and washers run up them before installing in the flange or all-thread cut to length.
Tom,The Mitchell company makes three different overdrives for the Model A. Their standard fits most Model A's. The one for the Victoria has a stub shaft that is 4.5 inches longer to locate the overdrive housing forward of the dropped floor pan. The third has a shorter stub shaft to accommodate later town sedans that have a floor pan for tool storage under the front seat. You can also order the overdrive with a 26% gear ratio and a 33% gear ratio.
Tom Endy
I will need to press this pinion assembly back into the banjo.
Does anyone have an old torque tube I could buy the flange off of?
Thanks Dodge.Yes. Check your PM
