jrvariel48
I adjust the pinion angle by having the rear axle tubes clamped to the springs but not welded to the housing yet. Should be close to the same degree but oppisite direction of what is at the trans. You can rotate the rear axle and make side to side adjustments also and then weld the pads that sit on the springs to the housings when you have the angle you want.
Basically this is the samt theory without cutting off the perches and rewelding. That's exactly what I did when I put the car together, but because the engine/trans angle has changed, I need to make the correction.
