Plainsman30
Hi All,
We did a partial rebuild on my motor after the first rebuild failed due to scored pistons.
I found that it pings at road speed if I give it more than 5 to 10 degrees advance as measured by a timing light. It has a new 5.5 head and a “touring grind” cam. It is bored .80 over with stock type pistons and has a stock carb and distributor.
At the present time, I have the initial timing set at 20 degrees retard, and it does cause a nice show idle, but it will still idle at 25 to 30 degrees retard.
I have checked the following:
- top dead center (TDC) mark was located on front pully according to when timing pin drops into dimple on timing gear.
- I can see the piston come to TDC with an inspection scope exactly when the pin drops into the dimple on the timing gear.
-The points are adjusted correctly.
- I am running premium gas, and the carb mixture setting doesn’t seem to make any difference on pinging.
The motor is still a little tight yet, but it runs nice and has good power and speed.
I wonder what could be causing this and whether or not I should worry.
