V12Bill
About 2 weeks ago I purchased a 1934 and a 1938 - 1940 engines along with some odds and ends parts. The 1934 engine " had run good when pulled" and no comment on the other engine. I got these engines home and noticed that the 1934 engine was missing half the teeth from the fiber timing gear. So much for "run good when pulled" At least I knew why the engine was pulled, at least not a rod that had let go. The heads were 68-**** and the pan had the crankcase vent in it, but these things could be changed. I soaked the engine in diesel fuel and after a few days the crank turned over. I pulled the pan and lo and behold the main studs were on 3 1/4 " centers. Yes it had inserts and was an LB engine without the LB stamped on the intake surface of the block. Some days even a blind squirrel finds an acorn!! I checked for cracks on the intake holes and found none. When I get the block stripped I'll get it boiled and magnafluxed. Keeping my fingers crossed.
